| Product(s): | AutoPIPE Vessel | ||
| Version(s): | V8i | ||
| Area: | Analysis | ||
| Date Logged & Current Version | Dec 2014 33.02.02.04 |
Capability to design the Flexible shell element (FSE / Thick Expansion Joint) as per section 8 of TEMA 9th edition in AutoPIPE Vessel?
AutoPIPE Vessel can design FSE as per section 8 of TEMA 8th only, in the TEMA 9th the analytic method has been replaced by guidelines to be used with a FEA method.
