Descartes Install - Get Error Message: "Install Higher Version"
 Product(s):Bentley Descartes for MicroStation
 Version(s):08.11.07.427
 Environment: N/A
 Area: Installation
 Subarea:
 Original Author:Frank McAllister, Bentley Technical Support Group
Problem Description
When installing Descartes user gets an error message to install a higher version of MicroStation or MicroStation Suite product.
Reason
In MicroStation or MicroStation Suite product  the Descartes installer checks for the “DCARTES.MA” file under the “…\Descartes\MDLApps” folder.   When the Descartes installer finds a suitable MicroStation or MicroStation Suite product in the registry, it checks for the “DCARTES.MA” file in the “…\Descartes\MDLApps” folder to see if Descartes has already been installed.  If the Descartes installer finds the “DCARTES.MA” file it will not allow you to install Descartes with that version of MicroStation or MicroStation Suite product.
Steps to Resolve
The “DCARTES.MA” file must be deleted or renamed before the Descartes installer will allow Descartes to be installed.
