On rare occasions I come across a coordinate system which is non-standard and can cause the user some headaches. Recently Igor, a Pointools user, had a dataset with a left-hand coordinate system which when imported and converted to POD caused it to appear mirrored.
I did some work with a surveyor from Singapore some years ago and remember that they use a LHS coordinate system, which we could compensate for while on site, i guess it is normal in some countries.
To correct this in Pointools is quite simple. Just figure out which axis the POD is mirrored on and scale the POD by -1 in that axis:
Once this is done go to Export and create a new copy of your POD with a unique name.
