| Product(s): | AutoPIPE Vessel | ||
| Version(s): | V8i | ||
| Area: | |||
| Subarea: | |||
| Date Logged & Current Version | aug. 2015 33.02.02.04 | ||
What value must be inputted as overpressure for Load conditions - Blast calculation in AutoPIPE Vessel ?
This is the value which allow to obtain in the calculation as an external pressure the value equal to the overpressure minus the internal pressure of the vessel.
For example:
Overpressure = 50 MPa; Internal pressure of the vessel = 2.5 MPa
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
