| Product(s): | AutoPIPE Vessel | ||
| Version(s): | V8i | ||
| Area: | Modeling | ||
| Subarea: | |||
| Date Logged & Current Version | July. 2016 40.01.00.09 | ||
Problem: How to perform analysis for Horizontal Shipping of Vertical Vessels (column)
Answer:
To make the calculation of a vertical vessel during the transportation horizontally, you may follow this workflow:
- Run the calculation of the vessel in its vertical position
- Convert results as input data (Menu/Execute/Convert Results as Input Data)
- Save the model under a new name
- Switch the vertical support to saddle support (Insert/Support...)
- The vessel is now in horizontal position
- Remove all unnecessary load combinations
- Add the transportation load combination
External Links
Comments or Corrections?
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
