Applies To | |||
Product(s): | Exor Mapcapture | ||
Version(s): | 04.05.00.03 | ||
Environment: | N/A | ||
Area: | Assets | ||
Subarea: | |||
Original Author: | Kristijonas Nalivaika, Bentley Technical Support Group | ||
Load fails in Inventory Loader (Part 1) when loading inventory file that was exported from MapCapture using "RMMS Inventory" export type. Spooled Output gives "Errors Detected during format checking". In the .lis following errors for every line of the inventory file are displayed:
ERROR: X Section - Less than 1 characters BPR-8041
ERROR: X Section - Invalid character BPR-8042
Having checked inventory file that is being loaded I can see that type B record is missing in the file.
This is due to incorrect MapCapture configuration. ‘Network Id’ and the ‘Unique’ field definitions in corresponding Asset Data Layers should match those in your network layer. See more detailed explanation below.
Right click on ‘Assets’ in the tree on the left -> Add Theme Wizard -> Add Theme Wizard. Choose corresponding asset type in the list on the left of the pop-up box that appears (as below). The ‘Network Id’ and ‘Unique’ fields on the right should refer to the corresponding fields in the shape file (as described in step 1).
MapCapture Configuration Guide.
