03. How to change the rates in AutoPIPE Vessel cost estimation module?
Answer:
The rates in AutoPIPE Vessel cost estimation module can be changed as follows:
Click on the "Customizable Files Management" icon and click "OK" then go to the tab "Rate and Time" and select the item at the list on the right and then change the rate as shown below:
Note that the rate units in the estimation module is currency neutral so the user has to be consistent with the choice of currency
