01. Are there any new Options for creating new cost estimation files in AutoPIPE Vessel
Answer:
There are 2 options to create a new cost estimation project in AutoPIPE Vessel:
1. Create from scratch
2. Use an existing .emvd model file that you have already created - in this case the items tag numbers and the geometry information are automatically imported from the .emvd file.
Click on File>New then select the applicable option:
