| Product(s): | AutoPIPE Vessel | ||
| Area: | Modeling | ||
| Subarea: | |||
| Date Logged & Current Version | Apr. 2016 40.01.00.09 | ||
Problem:
Need to add 10 vents of 2" in the below vessel component but the application only let me add 4. How can I add more Vents?
Answer:
Only 4 vents are allowed into the skirt. I assume that a workaround for these 10 holes into the skirt is to simulate the same opening wide with 4 holes of 5". It's just a suggestion I don't know if it works. AutoPIPE Vessel checks the minimal actual section in a plan considering holes to perform the calculation of the skirt.
