| Version(s): | ALL |
| Area: | Modeling |
| Date Logged & Current Version | July 2018 40.06.00.07 |
Is the role of jacket half coil considered for external pressure design?
Yes, the role of the jacket is considered for external pressure design, the design length between line of support is affected due to the coil.
See the image above showing design of external pressure for shell without and with jacket. Observe that the length between line of support 'L' is reduced when considering a jacket which leads to higher allowable external pressure resulting in a reduced shell thickness
