| Product(s): | Exor MapCapture | |
| Version(s): | 04.05.02.02 | |
| Environment: | N/A | |
| Area: | General | |
| Subarea: | N/A | |
Standard MapCapture not only allows you to create assets and inspections on network sections but also enables you to create inspections on assets.
- Download the shapefile for the asset layer of interest using Bulk Download – MCP0100 form.
- Add it into MapCapture together with your network layer shapefile (shapefiles are usually placed in the \MapCapture|Routes folder. Once it is there and MCP is open right-click on Network folder in the left pane then click 'Add Theme Wizard' and select the file). MapCapture should display both – network and asset layers on top of each other.
- Choose inspection type of interest and click on any asset on the map to create inspection - it should select (highlight) the asset rather than the network. A pop-up window should appear asking you to specify which asset you would like to select if you have not zoomed to the single asset before.
- Choose asset and create an inspection as you would do on a section. Once you export the inspection file – asset data should be visible in the export file.
MapCapture User Guide
| Original Author: | Kristijonas | |
