| Version(s): | ALL |
| Area: | Modeling |
| Date Logged & Current Version | June 2018 40.06.00.07 |
Why are Welded and Flange calculations grayed out on the Standard flange tab of the Nozzle Properties dialogĀ in AutoPIPE Vessel ?
The flange calculation option from standard flange dialog is opened only for vessel and heat exchangers. Other types (ex. aircooler / tank, special vessels) the option is disabled or grayed out.
