| Version(s): | ALL |
| Area: | Modeling |
| Date Logged & Current Version | Sept 2018 40.07.00.007 |
The Lifting lug orientation as per the software output results is not matching with the 3D model shown inthe Graphics window. Please clarify which one is correct i.e. software output or the graphic model ?
By default, the details of tailing lugs are not added to the drawing.
From the Customizable Files Management/Set Drawing layout and move to production, the template FOO1 = Lug – number 1 must be added to the layout, see help to more details.
The drawing generated is the following:
Again, the 3D model in the graphic view is correct, the one from the report is a general representation of the lug.
