| Version(s): | ALL |
| Area: | Drawing customization |
| Date Logged & Current Version | August 2018 40.06.00.007 |
How to customize the drawing Line weight for an exported AutoPIPE Vessel model into Microstation?
1. Start Microstation,
2. Open the Working File “up_seedt_mm.dgn” from the Customizable Database Files Path “C:\Users\Public\Documents\AutoPIPE Vessel_40.06.00.007\Config”
.3. Line Style Table:
4. Weight Table:
5. Color Table:
6. In the Working Directory “C:\Users\Public\Documents\AutoPIPE Vessel_40.06.00.007\Puser1”
For Microstation - Configuration file “up_param.cfg”
a. Microstation
Index = 2 (up_param.cfg) > Thickness = 2 in Microstation
Index = 4 (up_param.cfg) > Thickness = 4 in Microstation
Index = 0 (up_param.cfg) > Thickness = 0 in Microstation
In the file “up_param.cfg”, you can change the thicknesses
Drawing Customization - Change line thickness
