| Product(s): | AutoPIPE Vessel | ||
| Version(s): | all | ||
| Area: | General | ||
when entering data into the dialog screens of AutoPIPE Vessel, what does the different shading of each cell represent?
| Field Color | Description |
| Red (rose) | Indicates that the requested data MUST be entered. |
| Green | Indicates that the default data will be provided by the software but can be updated by the user as needed. |
| Yellow | Indicates that it is not necessary to modify this fields unless required by specific requests |
Find below the detail of units used in the UI (added after the value in the edit boxes):
Notes:
1. it is not possible to list the detail of the units used in the report, since they depend of the Code formulas and of the context.
2. It is not possible to change the force unit (daN), only the unit system itself can be changed (ex Us to SI).
