| Version(s): | ALL |
| Area: | |
| Date Logged & Current Version | June 2018 40.06.00.07 |
When creating my Drawing Layaut by choosing Execute --> Customizable Files Manager --> Set Drawing layout and move to production. In a dialog Set Drawing Layout, design new layout (new types and positions of views in the sheet) and choosing File --> Save as...
Then created a file with my Drawing layout (test.emav).
What should be done to use test.emav file as a template for Drawings?
In the folder “C:\Users\Public\Documents\AutoPIPE Vessel_40.07.00.007\Config”, you should rename
Rename from “Vueaux.emav” to “Vueaux.emav.old”
Rename from “test.emav” to “Vueaux.emav”
The file “Vueaux.emav” is the name by default.
If you change the file “Vueaux.emav”, do not forget to create a backup.
The file “Vueaux.emav” will be deleted if you uninstall AutoPIPE Vessel.
