| Version(s): | V8i |
| Environment: | N/A |
| Area: | Export |
| Date Logged & Current Version | May 2018 40.06.00.007 |
How to increase the dimension size or font size?
About Text Font in the 2D drawing.
About Text Size
Menu “Execute”
Menu “Manage Customization File…”
Hit the button “Set Drawing layout and move to production”
Menu “File”
Menu “Open”
Select “Vueaux.emav”
Select a view (Here the “FI” view)
Menu “View characteristics”
You can change the text size for all texts and dimensions in this view
Menu “File”
Menu “Save”
With this version and lower, one cannot not modify the dimension size or font size. This option will be included in a next release of AutoPIPE Vessel.
Steps for using Microstation:
Start AutoPIPE Vessel
Menu “Execute”
Menu “Manage Customization Files…”
Set the button “Set Drawing layout and move to production” (Run View manager)
Start View manager
Menu “File”
Menu “Open” “Vueaux.emav”
Select “Pressure vessel”
Select “Horizontal”
Select “1 chamber”
Select Format “A0”
Select Sheet “1”
Select the view “WE”
Double the text size and the dimension space
Hit the button “OK”
Menu “File"
Menu “Save” “Vueaux.emav”
Before
After modifications ( All dimension and text sizes have been doubled )
