| Version(en): | V8i, CONNECT, 2023, 2024 | ||
| Umgebung: | N\A | ||
| Produktbereich: | Benutzerdefinierte Stricharten | ||
Wie löst man alle Benutzerdefinierten Linienarten in einer Datei auf?
Dies führt dazu dass alle nicht zugeordneten Benutzerdefinierten Stricharten aufgelöst werden auch wenn Sie z.B. in DWG/DXF-Dateien unterstützt werden würden.
Im unteren Teil des "LineStyle"-Excel-Blattes ist folgende englische Hilfe enthalten:
LineStyle – the name or number of the source line style to remap
V7OutputLineStyle – the name or number of the line style when saved to V7 file
V7OutputScale – the scale factor for the style when saved to V7 file. If the entry is blank, 1.0 is used.
V8OutputLineStyle – the name or number of the line style when saved to V8 file
V8OutputScale – the scale factor for the style when saved to V8 file. If the entry is blank, 1.0 is used.
DWGOutputLineStyle – the name of the line style when saved to DWG or DXF file
DWGOutputLineStyleFile – if the output line style is defined in an Autocad line style file, this entry is the ".lin" file that contains the line style. The default is "acad.lin". MicroStation attempts to find the file in the "support" directory of an Autocad installation on the system, or you can specify a full file path.
DWGOutputScale – the scale factor for the style when saved to a DWG file. If the entry is blank, 1.0 is used.
Level, Color, Weight, Class, ElementType,Cell - optional qualifier columns, see Instructions worksheet.
The keyword "%drop" can appear in any of the OutputLineStyle columns. When it does, any element with the corresponding LineStyle is stroked to multiple elements that represent the appearance of the source element. The numbered linestyles cannot be dropped.
If the keyword "%unmapped" appears in the LineStyle column, then every element that has a line style that does not otherwise appear in the LineStyle column is mapped to the destination specified in the %unmapped row. If there is more than one %unmapped row in the section with the same values for the qualifiers columns, the last one is used.
If the value in the LineStyle column is enclosed in square brackets it is interpreted as "effective linestyle". For example, if the LineStyle column contains "[3]" then the remapping applies if either the element linestyle is 3 or the element has its linestyle set to ByLevel, and the ByLevel linestyle of its level is set to 3.
If the keyword "%bylevel" appears in the V8OutputLineStyle or DwgOutputLineStyle column, then every element that has the line style indicated is changed to be ByLevel. The V7 file format does not support ByLevel, so that keyword is invalid in the V7OutputColor column.
Linienarten / Stricharten auflösen
All about Custom Line Styles
| Ursprünglicher Autor: | Yvonne Lohse |
