| Product(s): | AutoPIPE Vessel | ||
| Version(s): | V8i | ||
| Area: | drawing | ||
| Date Logged & Current Version | Jan. 2016 40.00.00.17 |
How to add customized weld details in AutoPIPE Vessel?
You can create your own weld blocks and insert them in the formats. You can also move APV weld blocks into the view manager.
You can access the documentation concerning the view manager.
