| Product(s): | AutoPIPE Vessel | ||
| Version(s): | V8i | ||
| Area: | drawing | ||
| Date Logged & Current Version | Jan. 2016 40.00.00.11 |
How automatically to add your own title block instead of the AutoPIPE Vessel title block ?
The easiest way is to change the blocks " NHTIA0 " et " NLTIA0 " in the libraries.
Example for the format A0 and other formats, you can change the blocks " NHTIA0 " et " NLTIA0 " .
You can also create your own title block with a name used by you but you must change all formats used by you in the view manager and insert it if this block has not the same dimension. (a lot of formats)
If you changed the view file " vueaux.emav ", do not forget to save it because if you install again a APV release, this file will be overwritten.
