| Version(s): | ALL |
| Area: | Drawing customization |
| Date Logged & Current Version | May 2018 40.06.00.007 |
Can we reduce the thickness of line. Some dimensions are not visible.
Every time we need to scale up in autocad
About Line Style, Thickness, Color
In the Working Directory “C:\Users\Public\Documents\AutoPIPE Vessel_40.06.00.007\Puser1”
For AutoCAD Configuration file “ap_param.cfg”
For Microstation Configuration file “up_param.cfg”
In the Customizable Database Files Path “C:\Users\Public\Documents\AutoPIPE Vessel_40.06.00.007\Config”
For Microstation Working file “up_seedt_mm.dgn” Millimeters
For Microstation Working file “up_seedt_in.dgn” Inches
For AutoCAD Working file “apacadmm.dwg” Millimeters
For AutoCAD Working file “apacadin.dwg” Inches
