| Product(s): | Exor Core / Network / Assets Manager | ||
| Version(s): | 4.2.0.0 | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
Error when running CSV Load: ORA-06550: line 72, column 84: PLS-00103: Encountered the symbol ";" when expecting one of the following: . ( ) , * % & | = - + < / > at in is mod remainder not range rem => .. <> or != or ~= >= <= <> and or like LIKE2_ LIKE4_ LIKEC_ as between from using || multiset member SUBMULTISET_ The symbol ")" was substituted for ";" to continue.
Error was caused by a mistake in the syntax of the 'source column' entry in hig2020 - CSV Loader File Definitions Tables. It can be that a bracket is missing from a statement similar to
this:
UPPER(NVL(TRIM(TABLE.COLUMN,'UNKNOWN')) should have been UPPER(NVL(TRIM(TABLE.COLUMN),'UNKNOWN'))
