Enable the editing of nested reference levels
AskInga logo
Original Tip Date: May 10, 2004
To enable the editing of nested reference levels
By default you can not adjust the overrides for a nested reference.
Go to File/Settings/Configuration/Configuration Variables
Select Category - Levels
This can be changed by setting: MS_LEVEL_EDIT_NESTED_ATTACHMENT_LEVELS=1
Edit Variable to 1
Once ON, nested attachment levels editing will be enabled in the Level Manager as shown below.
This and a whole lot more can be found in the ReadMe file.
MS_Level_Edit_Nested_Attachment_Levels variable is Undefined in Workspace
MS_Level_Edit_Nested_Attachment_Levels variable is now set to 1
Variable is set
AskInga Tip #437
