Answer:
In the Tubesheet Layout tab enter the value of shell ID in the Internal Diameter field, keep the Tube Number field blank, then Compute.
Remember, it may not be possible to maintain both tube numbers and shell ID so enter ONLY one quantity, whichever you want to maintain, the program automatically calculates the other quantity based on the input data.
Bentley Select Services Technical Support webpage:
the "Comments" area below. THANK YOU!
