Answer:
At first set the Main Vessel Diam. to External in the Geometry tab:
Run calculations and then for each individual shell change the diameter to nominal and select the appropriate NPS from dropdown:
Save and rerun the file.
Bentley Select Services Technical Support webpage:
the "Comments" area below. THANK YOU!
