Original Tip Date: Jul 11, 2006
| Missing edit handles? | |
| Are you missing the edit handles in MicroStation V8 XM Edition? If so, check the Disable Handles option in the Tool Settings dialog when Element Selection tool is active. This public service announcement is brought to you today by Phil Chouinard. Related Tip: Alternate Text Editing Handles In XM | |
AskInga Tip #660
