22. Where do we mention MMT (Mean Metal Temp) in AutoPipe Vessel for Fix tube sheet Heat Exchanger?
Answer:
The design conditions are automatically generated with temperatures for tubesheet design, these (including the shell, tube, channel and tubesheet temp.) can be modified in the Tubesheet Properties>Design Conditions tab:
