Original Tip Date: Oct. 6, 2003
| Set up a seed file for your UPF file | |
Getting tired of having to reset your user preferences after you've deleted your UPF file? If so, then utilize MS_USERPREFSEED. If you want MicroStation to create a new UPF from from MS_USERPREFSEED, then set MS_ALWAYS_CREATE_UPF = 1 | |
AskInga Tip #316
