| Version(s): | ALL |
| Area: | Modeling |
| Date Logged & Current Version | June 2018 40.06.00.07 |
How to change the the corrosion allowance for clad bottom plate on a heat exchanger model
The clad thickness is always considered like a corrosion allowance in AutoPIPE Vessel. To resume, if you input 1 mm of cladding, that is exactly the same thing as if you input 1mm of corrosion allowance.
