| Version(s): | ALL |
| Area: | |
| Date Logged & Current Version | March 2018 40.06.00.07 |
How to add TEMA Metric Bolt Root Area (TEMA Table D-5M) from section 9.
Metric Bolts dimensions are in the file "boltiso.xls" and can be modified if needed (customizable file).
Suggest to create a separate “Config” folder in which you can copy and update the bolt file. To use this specific “Config” folder there are 2 possibilities:
a. copy the folder in the same directory as the EMVD file (the files in this folder will be used in priority).
or
b. Input the pathname in the “Design Parameter” Tab of “Shell and Tube Exchanger Properties” Dialog.
Thus, you will have a separate table of Metric Bolts that can be used for all models of a same project.
Modeling techniques for Shell and Tube Heat Exchangers
