| Version(s): | V8i |
| Area: | Modeling |
| Date Logged & Current Version | August 2016 40.02.00.08 |
The user would want 2 rows of 5 bolts (10 bolts) for the base plate of a Saddle support. He ask if there is a mean for modeling these 10 bolts?
This is not possible at this time, currently there are only 2 possibilities:
• 1 row of 2 bolts (2 bolts)
• 2 row of 2 bolts (4 bolts)
This feature is not available in AutoPIPE Vessel, a workaround would be to increase the bolting area.
Modeling techniques for Shell and Tube Heat Exchangers
