Original Tip Date: May 15, 2003
| Force references to be attached Coincident - World or Coincident | |
| To force references to be attached Coincident - World, set either of these configuration variables: MS_REF_COINCIDENTWORLD=1 or MS_REF_DEFAULTSETTINGS = attachmethod=world To force references to be attached Coincident, set this configuration variable: MS_REF_DEFAULTSETTINGS = attachmethod=coincident You'll have to close and re-open the file for this to take effect | |
AskInga Tip #277
