Original Tip Date: Nov 6, 2006
| If copying from the clipboard doesn't work | |
| Here's an interesting piece of information that Josh Schifter shared on the discussion groups. When you're using the clipboard to copying and paste elements between files, MicroStation creates a file called clipboard.dgn in it's temp folder. This folder is typically set to \Bentley\Program\MicroStation\temp\ and not having write privileges to it may cause problems with clipboard operations. | |
AskInga Tip #680
