Q. Why is tubesheet layout not full of tubes?
Example:
The removal of tubes in bundle layout can happen due to several reasons:
    1. Manually removed tubes from Tube Bundle Properties dialog in previous step of the heat exchanger modeling session.
    2. Maintaining pass tolerance
    3. To maintain height between tubes with impingement baffle
    4. To maintain the TEMA inlet outlet condition requirement when ‘compute’ field in Bundle dialog box is checked to verify shell entrance and exit areas as per the TEMA calculations
    5. Bundle Properties (open Shell and Tube Heat Exchanger Properties dialog)
      1. Flow Section values and options used (example, uncheck "Compute" option, Delete "Free height" values)
    6.  See output report Flow section for this calculation when compute is checked and flow verification need to be performed:
Once all of the settings have been adjusted, open the Shell and Tube Heat Exchanger Properties dialog, Cross View tab, and press the Compute button
Done, the area defined by the model will be filled in with tubes.
Shell and Tube Heat Exchangers
AutoPIPE Vessel
Bentley LEARN Server
