| Version(s): | ALL |
| Area: | Modeling |
| Date Logged & Current Version | June 2018 40.06.00.07 |
For a shell and tube exchanger with fixed tubesheets, the software is locked with the "Mechanical cleaning" option even if the option is unchecked?
The Gap Groove/Tube is too important, remove it, then compute once in Cross View to have an acceptable bundle, click OK to validate changes.
Then in Longitudinal View, compute to reorder baffles click OK to validate changes.
It should be OK then.
