Answer :
The process to optimize the flanges is to find the maximum of small bolts to ensure the sealing of the gasket.
In AutoPIPE Vessel, 2 main choices can be done in the Flange dialog to obtain a compact forging in which the hub has a small length or a light flange with a important hub and a flange with a small thickness.
