Answer:
2D AutoCAD, 2D Microstation, as well as 3D AutoCAD, 3D Microstation and 3D SolidWorks models are automatically created from AutoPIPE Vessel.
Export to Pro/E 3D model is not possible directly but it can be done by creating Microstation 3D model first and then converting that to Pro/E.
Below is an example of a detailed dimensioned fabrication type sketch generated in Microstation:
Check towards the end of this document for more examples.
Drawing/3D model generation feature, cost estimation module are all included in base price at NO extra cost.
