122 CHECKING DATA : Data in this file are obsolete, save it with the latest release to convert data
Answer:
In one reported case, when computing local loads on a cylindrical shell, the error message was displayed:
"122 CHECKING DATA : Data in this file are obsolete, save it with the latest release to convert data or use a previous release."
What is generating this error?
The implementation of load cases has been extend to all kind of studies. In the case of a design component, this enhancement is not used, but generate unfortunately error message - 122 Checking Data. This message has no influence on the result of the calculation (material not found, but not required here).
This issue was logged (TFS-245127) and fixed in AutoPIPE Vessel 40.00.01 and higher.
