17. Is it possible to have in AutoPipe Vessel different standards for projection nozzles so that you
Product(s): AutoPIPE Vessel
Version(s): V8i
Area: Modeling
  Date Logged
& Current Version
Mar. 2015
33.02.02.04
Problem:
Is it possible to have in AutoPIPE Vessel different standards for projection nozzles, so that you can choose the desired standard with one mouse click?
No, currently it is not possible to have multiple defaults for nozzle projections, only one value can be set (both for US and SI) in the defval.doc file in the config folder.
Nozzle and Flange design
