11. How to design Nonstandard flanges on standard Nozzles?
Answer:
Custom flange on standard nozzle is not currently possible(possible enhancement).
However a separate analysis for the non standard flange can be performed using the component design option and designing a custom flange.
In the “Body Flange” Dialog there is a Button to retrieve the dimensions of a Standard Flange (see below).
