08. How do I model a nozzle on the bottom of a tank?
It is not possible to put a nozzle on the bottom of a tank (tank floor).
Might I suggest if you need a drain for a tank design that you put the drain nozzle at a low elevation on the side of the tank wall and provide internal piping to allow for the tank to drain by siphon.
