Currently only standard flange can be designed for a nozzle.
If you want to design a custom flange for your nozzle, you have to design and calculate the flange and cover separately, go to Component Design mode after you select File>New:
Then select Body Flange and Cover and complete the flange and cover design:
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
