07. How to make modification to existing standard flange material ?
Product(s):AutoPIPE Vessel
Version(s):ALL
Area:Material Update
Date Logged
& Current Version
March 2020
41.04.00.013
Problem:
 Right click on a component and select “Change Material”:
Select nozzles which need to be modified:
Change the "Symbolic Name" material setting as needed (ex. SA 105):
Change "Apply Change" setting from "Main Component" to "Nozzle Flange Material” to apply selected material on nozzle flange material:
Enable “Change Material” checkbox to apply selected material on selected components:
Click “Apply” to apply modification.
For body flange as standard flange, select “Main Component” instead of “Nozzle Flange Material”
AutoPIPE Vessel
Bentley LEARN Server
