| Product(s): | AutoPIPE Vessel | ||
| Version(s): | V8i | ||
| Area: | Interface | ||
| Date Logged & Current Version | Mar. 2015 33.02.02.04 |
How to Customize the AutoPIPE Vessel Toolbar
1. Within AutoPIPE Vessel, double-click anywhere to the right of the last icon in the toolbar to display the Customize Toolbar dialog.
2. To add a toolbar button to the Main Toolbar, select the appropriate item from the Available toolbar buttons list, then press Add >.
3. Use the Move Up and Move Down buttons to position the toolbar button in the appropriate location.
4. To remove a toolbar button from the Main Toolbar, select the appropriate item from the Current toolbar buttons list, then press < Remove.
5. To place a separator between the buttons in the Main Toolbar, select the insertion point for the separator by clicking on a button in the Current toolbar buttons list, then select Separator from the Available toolbar buttons list, then press Add >.
6. Press OK save the changes and exit the Customize Toolbar dialog.
