| Product(s): | AutoPIPE Vessel | ||
| Version(s): | V8i | ||
| Area: | |||
| Subarea: | |||
| Date Logged & Current Version | 2014 33.02.02.04 | ||
How to export AutoPIPE Vessel models to CAD softwares? What CAD softwares are available for exporting from AutoPIPE Vessel?
AutoPIPE Vessel models can be exported to Microstation, SolidWorks and AutoCAD 2D and 3D file formats.
To set the CAD output preference, go to menu File, then click on Preference and from the drop down under CAD Software Name select the appropriate
For example, if you want to export to SolidWorks 2014 V 64 bits, select that from the dropdown list:
Open the tab "Set Default Data" and select the option "Create 3D drawing" and click OK.
Complete the design and run the analysis. After the analysis is complete, click on the Drawing Generation icon;
The "Drawing" dialog box appears. Make sure that the Generic File Name shows the intended file path to save the generated SolidWorks files. Click OK.
The SolidWorks file export should now be complete.
A video of the AutoPIPE Vessel to SolidWorks integration can be watched using the following link:
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
