07. Where do you find the nozzle orientation on the exported AutoPIPE Vessel drawings?
Answer:
While creating the drawing, make sure you check "Setting Plan and Initial Flat View" and then on sheet 1 you would find the nozzle orientation, projection etc. at the bottom of the sheet in the nozzle table:
Drawings created by AutoPIPE Vessel
Bentley AutoPIPE Vessel
