Follow the steps below to add Bill of Material (BOM) table to the drawing:
1. Open and Run the view manager:
2. Open vueaux.emav and make the changes
The 'Vueaux' file location is as follows:
Select the correct type and format
Remove an existing Block to create a free space
Add the BOM Block and place it
Select the item eg. '0018 = BOME01 +bom.xls' with left mouse button and click on the desired space on the drawing sheet and release it by clicking once more:
Save and Close the 'Vueaux' file:
3. Create the drawing (.dgn)
4. Create the excel spreadsheet:
The Excel file is created
Add the table in the drawing
6. Run DGN viewer
There is also a tutorial in the Help:
Drawings created by AutoPIPE Vessel
