| Version(s): | ALL |
| Area: | Modeling |
| Date Logged & Current Version | June 2018 40.06.00.07 |
Why user cannot chose any code except ASME VIII for air cooler design. What about API 661?
On the Design Parameter tab, lower left hand corner is the option to select a standard, select the radio button next to API 661.
Note: API 661 is a standard and where ASME Section VIII is a pressure design code. From API Standard 661 /Iso 13706: 2001:
