| Product(s): | AutoPIPE Vessel | ||
| Version(s): | V8i | ||
| Area: | Install | ||
| Date Logged & Current Version | April. 2018 40.06.00.007 |
The following appeared when installing AutoPIPE Vessel
Unknown Procal release -- Release Error 1
O sistema nao conseguiu localizar o ficheiro especificado
OK
Why and how to fix it?
Only solution at this time is to look at your company's antivirus / malware application to see if some files are being deleted and /or put it in quarantine.
Ask company IT department to add AutoPIPE Vessel and all installed files as a trusted source.
