| Product(s): | AutoPIPE Vessel | ||
| Version(s): | V8i | ||
| Area: | Install | ||
| Date Logged & Current Version | Oct. 2015 40.00.00.11 |
The following appeared when installing AutoPIPE Vessel
An error occurred during the installation of assembly 'BentleyRSS, version="1.1.0.0",culture="neutral",publicKeyToken="48F6C96A266E58D4",processorArchitecture="x86", Please refer to Help and Support for more information
Why and how to fix it?
Press the OK button to continue
The following screen will appear:
Press the Finish button to continue.
Next, press the Restart button to reboot the computer
Note: if you select the log File hyper link above, the following log file would have appeared. Notice the Errors near the bottom of the listing:
Error 0x80070643: Failed to install the MSI package
After rebooting the computer restart the installation process by double clicking the downloaded EXE file again.
If you continue to have troubles please log a Bentley Service Request.
